Coordinate transformation of lagrangian
nlake27
Hey all,
According to my physics textbook, if the potential energy of a particle is a homogeneous function of the spatial coordinate r, one can transform r by some factor a and t by some factor b=a^(1-.5k) such that the Lagrangian of the particle is multiplied by a^k. I understand all of this, but I do not understand how one gets from here to the result given: t'/t=(l'/l)^(1-k/2); t'/t being the ratio of the times along the paths l and l'.
My textbook has some problems that require (I assume) similar logic ("Find the ratio of the times in the same path for particles having the same mass but potential energies differing by a constant factor").
The book solution is t'/t=(U/U')^(1/2); I tried solving it by making the "constant factor" a^k so that l=a*l', which eventually gives me an answer that is off by a factor of 1/a. If someone could explain the logic that leads to the derivation of the equation in bold, I'm pretty sure I can find the error in my own calculations.
Well, you've got two coordinate transformations r'=ar and t'=a^{(1-k/2)}t. Now suppose we let l and l' be the paths traversed by the particle in times t and t' respectively. Then the first equation yields a=l'/l which can be substituted into the second equation to give t'=\left(\frac{l'}{l}\right)^{(1-k/2)}t.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
