Efficiency of a Cart Rolling Down an Inclined Plane
The discussion focuses on calculating the efficiency of a cart rolling down an inclined plane. The user provides specific measurements, including the height of the incline, the length of the board, the mass of the cart, and the force applied to pull it up. They calculate the energy input as 1.694 J using the work formula W = Fd. There is uncertainty about calculating energy output, with a suggestion to use kinetic energy but concerns about double counting losses. The conversation emphasizes the need to determine the energy the cart has at the top of the incline for accurate efficiency calculations.
xRadio
Alright for this thing, we had to pull a cart up a inclined plane and time how long it took to get to the bottom.
Distance from ground to top of inclined plane is - 0.125m
Length of Board is - 1.21m
Mass of cart - 1.09kg
Force to pull cart up - 1.4N
Time it took for cart to roll down board - 1.92s
So I need to calculate:
Energy Input (pulling cart up)
Energy Output
Efficiency
W = Fd
Eff = Useful output energy/Input Energy x 100%
So I am guessing Energy Input is
W=FD
W=(1.4)(1.21)
W = 1.694 J
Would Energy output be
E = 1/2mv^2?
I don't think so, wouldn't that be counting your losses twice? It takes 1.7 joules of input energy (Work) to pull the cart up to the top of the plane. How much energy does it have when it gets there?
