How Much Heat to Turn Ice at -10°C into Water at 20°C?
  • Thread starter Thread starter navy_bison
    Heat Latent heat
To convert 395 g of ice at -10°C to water at 20°C, the total heat required is calculated by heating the ice to 0°C, melting it, and then heating the resulting water to 20°C. The initial calculation yielded 43.45 kcal, but the correct total is approximately 41.5 kcal. The process involves using specific heat values for ice and water, as well as the latent heat of fusion for melting. A general formula for calculating latent heat is mass times the coefficient of energy per unit mass. Understanding the steps and using accurate values for specific heat is crucial for solving such problems effectively.
navy_bison
How much heat is necessary to change 395 g of ice at -10°C to water at 20°C?
mLf + mc(delta)T
(.395kg)(80kcal/kg)+(.395kg)(1.00kcal/kg x 1 deg C)(20--10)
(31.6kcal)+(.395kcal degC)(30)
31.6kcal + 11.85 kcal=43.45 kcal
I got the answer wrong obviously, the correct answer should be 41.5 kcal. Please help me, my teacher isn't so great and an explanation as to where I went astray would be appreciated. Thanks
navy_bison: zzz:
i. Heating 395g ice at -10C to 0C
0.395[kg]*10[k]*2100[J/kg*K] = 8295J
ii. Melting 395g ice
0.395 * 333000 = 131535 J
iii. heating 0C water to 20C
0.395 * 20 * 4190 = 33101J
total = 172931 J
1kcal = 4 184 J
172931J = 41.34 kcal [depends on what values on the specific heat constants you use, and so on]
What is the general formula for figuring the latent heat using J? The example in my book (it's been 10 years since a science class for me) only uses the kcals to calculate the number. I'm not understanding exactly where the numbers you've used are coming from. Is there a good website that you know of that could go more indepth?
I used the number from my textbook.. It doesent matter what units you have, you can always convert them.
There is only one general forumula for calculating latent heat:
mass * coefficient[energy/units of mass] = Energy
Thanks for the help, I've found a table that represents these specific heat vaules. I understand know that the ice must be heated, then melted (latent), then heated again. Add these up and get the answer. Thank you so much for the help. Recommending this site to all the people in my class!
good luck!
hehe but remember to contribute with help yourselves... and also to search a bit for old topics considering similar problems.
