Weight of block and static friction
The block weighs 84.0 N, and the coefficient of static friction with the wall is 0.520. To prevent the block from sliding down, the minimum force required must equal the weight, adjusted for static friction. For upward movement, the applied force must exceed both the weight of the block and the static frictional force acting downward. Understanding the relationship between normal force, friction, and weight is crucial for solving these problems.
rcmango
The weight of the block in the drawing is 84.0 N. The coefficient of static friction between the block and the vertical wall is 0.520.
(a) What minimum force is required to prevent the block from sliding down the wall? in Newtons
(b) What minimum force is required to start the block moving up the wall? (Hint: The static frictional force is now directed down the wall.)
in Newtons
having problems figuring this out, is there a formula for the force sliding down the wall.
also, wouldn't the minimum be the .520 just the static force?
thanks.
For a static situation, the friction (using static coefficient) must equal the weight.
Friction is given by the product of normal force and coefficient of friction \mu.
To get the block moving vertically, the applied force must exceed the weight AND friction.
Friction acts in either (both) directions.
