Electric Field in Dielectric: Charge Distribution & Calculations
Qyzren
Two identical, oppositely-charged, conducting plates of area 2.50cm² are separated by a dielectric 1.80 mm thick, with a dielectric constant of 3.60. The resultant electric field in the dielectric is 1.2*10^6 V/m.
a)Compute the charge per unit area on the conducting plate.
b)Compute the charge per unit area on the surfaces of the dielectric.
for part a). I used gauss's law for dielectric.
Q/A = K*epsilon_0*E = 3.60*8.85*10^-12*1.2*10^6 = 3.82*10^-5 C/m² which is correct.
However i haven't got a single clue how to do part b. But the answer is suppose to be 2.76*10^-5 C/m². Can someone please help me figure out how this answer was obtained?
For b, they must mean bound surface charge density, which equals the normal component of the polarization vector P.
thank you for help. i managed to figure it out now with your tip :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
