Circular Angular Acceleration problem
The problem involves calculating the acceleration of a stone stuck in the tread of a tire spinning at a constant speed of 60.0 mi/h. The tire's diameter is 2.00 feet, leading to a radius of 0.305 meters. The initial calculations for angular velocity (ω) and tangential acceleration (a_t) were incorrect, as the correct approach involves using centripetal acceleration. The proper formula for centripetal acceleration is a_c = v^2/r, where v is the linear speed converted to meters per second. Ultimately, the correct centripetal acceleration is approximately 2350 m/s².
the7joker7
A tire 2.00 feet in diameter is placed on a balancing machine, where it is spun so that its tread is moving at a constant speed of 60.0 mi/h. A small stone is stuck in the tread of the tire. What is the acceleration of the stone as the tire is being balanced?
\omega = \frac{change in theta}{change in time}
r = diameter/2
\alpha = \frac{\omega - \omega_{0}} {time}
a_{t} = r*\alpha
\omega = 840.3 rev/min = 88 radians/sec.
radius = .305m.
\alpha = \frac{88 radians}{1 second} = 88 radians/second^{2}.
a_{t} = .305 *88 = 26.84 m/s^{2}
You got omega (I'll call it w) just fine somehow. I'm not sure how because it's not clear what you did. But acceleration isn't w*r, that's velocity v. 26.8m/sec=60mi/hr. You are back where you started. Acceleration is v^2/r=(w*r)^2/r=w^2*r.
Well, going from 60mi/hr to radians/second is pretty basic math as long as you know the transformation values.
Thanks for the help!
EDIT: I got 88^{2} * .305 = 2631.92radians/seconds^{2}. Look right?
Use the equation centripetal acceleration = v^2/r. The radius s 1.00 ft, or .305 m. V is 60 mi/h, or 26.8 m/s. Then the acceleration would be (26.8)^2/0.305, which is 2350 m/s^2
