How to Write Formulas in Physics Forums
A particle is subjected to a net force F(x) = Cx^2 while moving from x_initial = L to x_final = 3L, leading to a discussion about calculating the change in kinetic energy, deltaK. The work done on the particle is calculated using the integral of the force, which is independent of the particle's speed. A user reported an incorrect result of 16CL^3 and sought clarification on the calculation process. Another participant emphasized the importance of not posting complete solutions to homework questions in the forum. For writing formulas, users are directed to a LaTeX tutorial available in the Physics Forums.
horsegirl09
A particle moving in the x direction is being acted on by a net force F(x)= Cx^2, for some constant C. The particle moves from x_initial= L to x_final= 3L. What is deltaK, the change in kinetic energy of the particle during that time?
Express your answer in terms of C and L.
I got 16CL^3 but it keeps saying I'm off by a multiplicative factor. Anyone know where I', going wrong?
The work done on your particle as it moves in the positive x-direction is:
W = \int_{x=L}^{3L} F(x) dx
Interestingly, this is independent of how fast the particle is travelling.
In your case, you have an explicit form for the force: F = Cx^2, so:
W = \int_{x=L}^{3L} Cx^2 dx
<< rest of complete solution edited out by berkeman >>
Is this better?
thanks!
hi pterid ... how do u write formulas ??
best regards
rayo
Is this better?
pterid, Please do not post complete solutions to homework/coursework questions. Even though this thread was originally (incorrectly) posted in the general technical forums, it is easy to recognize it as a homework/coursework question, and should be treated as such, even before a Mentor notices it and moves it to the Homework Help forums.
