Electric and magnetic fields with electron
An electron is traveling through an electric field E and a magnetic field B, with E oriented along the y-axis and B perpendicular to both E and the electron's velocity. The net force acting on the electron is represented as a function of its speed, showing a linear relationship on a graph. The relevant equation for the net force is Fnet = q(E + v x B), leading to the conclusion that B can be expressed as B = E/v when Fnet equals zero. The challenge lies in determining the values of E and B, particularly since the problem lacks sufficient information to relate voltage to velocity. Further assistance is requested to complete the solution, particularly in finding E.
cas111
at time t1, an electron is sent along the positive direction of an x axis, through both an electric field E and a magnetic field B, with E directed parallel to the y axis. Figure 28-34 gives the y component Fnet, y of the net force of the electron due to the two fields, as a function of the electron's speed v at time t1. the x and z components of the net force are zero at t1. Assuming Bx=0, find the magnitude E and B in unit-vector notion.
the graph has the y-axis set as the net force in the y direction and the x-axis as the velocity of the electron. the y-axis goes from -2 through 2 and the x-axis goes from 0 to 100. the x-axis is zero at -2 on the y axis, and 100 at 2 on the y axis. the graph is a straight line through those two points.
im not really sure
to be honest i have no idea where to start on this one, any help would be appreciated.
I think I'm in your class. I don't know if this is right but I think I have the idea.
Ok, becuase B is always perpendicular to v and E, B should be pointing in the page in the k direction. The formla you should use is Fnet=q(E+VxB) E,V,B are vectors. Becuase V and B are parallel their cross product is vB so now Fnet=q(E+vB). Your vectors will be stright lines when Fnet=0 so 0=q(E+vB). Obviously the q goes away and you are left with B=E/v, where E is the only vector. From here it gets a little trick. You have to use the KE formula for velocity. This is as far as I have gotten becuase you have to use voltage in the KE formula and I can't find a relation in the problem to get velocity for anything. If you figure the rest out could you post it so I can finish? I couldn't find the problm in the soultions manual unless it is number 7. 7 doesn't have a part b and it doesn't tell you how to find E. It uses V/m to find E, and again I have to clue to to find V.
