How Do Water and Mercury Pressures Compare in Different Height Containers?
In comparing the pressures of water and mercury in containers of different heights, the pressure from water at 10 cm is calculated as 10 g/cm², while the pressure from mercury at 5 cm is 70 g/cm². The ratio of mercury pressure to water pressure is 7:1, indicating that mercury exerts significantly more pressure due to its higher density. However, when considering total pressure at the bottom of the containers, atmospheric pressure must also be factored in, which alters the ratio slightly. The difference in pressures remains independent of atmospheric pressure, emphasizing the importance of density and height in pressure calculations. Understanding these principles is crucial for accurately comparing fluid pressures in various contexts.
Gear2d
If you have two containers one with water (filled to 10cm) and one with mercury (5cm), how do the pressure of water and mercury compare?
p of water = 1 gm/cm^3
p of mercury = 14 gm/cm^3
P = pgh where p is density, and h is height
P water = (1)(10) = 10 (I am not include gravity since its the same for both and they are only looking for a ratio)
P mercury = (14)(5) = 70
Would the correct answer be: 7*Pwater = Pmercury ?
Correct, although if they were looking for the RATIO of total pressure at the bottom of the two containers then you do have to consider the air pressure.
70 / 10 is not quite the same as 70+atm / 10+atm (ps. 1 atm is roughly 1000g/cm^2)
The DIFFERENCE between the pressures doesn't depend on the atmosphere.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
