Voltage at Halfway Point Between Point Charges in an Equilateral Triangle
The discussion centers on calculating the voltage at a point halfway between two point charges in an equilateral triangle configuration. The charges are +Q, +2Q, and -4Q, with a side length of L. The voltage is derived using the formula Vnet = V1 + V2 + V3, where the individual voltages are calculated based on their respective distances. There is some confusion regarding the distance used in the calculations, particularly for the -4Q charge, with participants correcting each other on the use of L and cos(30). The final expression for the net voltage is simplified to Vnet = kQ[(2/L) + (4/L) - (4cos30/L)].
rissa_rue13
There is an equilateral triangle with one point charge at each vertex. The point charges have charges of +Q, +2Q, and -4Q. The length of one side of the triangle is L. Determine an expression in simplest form for the voltage at a point halfway between the +Q and +2Q point charges.
V=kQ/r
Vnet=V1+V2+V3
Going off of Vnet=V1+V2+V3:
Vnet= (kQ/r) + (k2Q/r) - (k4Q/r)
I think once substituting the values for L in place of r, you get:
Vnet= (kQ/(L/2)) + (k2Q/(L/2)) - (k4Q/Lcos30)
Am I heading in the right direction?
Yes, that looks good.
I think I made a mistake, I think it should be:
Vnet= (kQ/(L/2)) + (k2Q/(L/2)) - (k4Q/(L/cos 30))
This can then be simplified:
Vnet=kQ[(2/L)+(4/L)-(4cos30/L)]
Am I on the right track?
The distance from the far vertex is L(cos 30). I think you were right the first time.
