How Do You Calculate Resistor Values in a Circuit?
  • Thread starter Thread starter shinobi12
    Resistance
To calculate the resistor values in the given circuit, the battery's emf is 15.0 V, and the terminal voltage is 11.6 V while delivering 20.0 W to an external load resistor R. The equations for Ohm's Law and power (P = VI, P = I²R) are essential for solving the problem. The internal resistance of the battery can be modeled as a resistor in series with the ideal voltage source. A circuit diagram can help visualize the relationship between the external and internal resistances. Understanding these concepts is crucial for determining both the value of R and the internal resistance of the battery.
shinobi12
trrttA battery has an emf of 15.0 V. The terminal voltage of the battery is 11.6 V when it is delivering 20.0 W of power to an external load resistor R.
(a) What is the value R?
(b) What is the internal resistance of the battery?
I'm sure how to start this problem. I'm sure I get rolling if I can just get some momentum started. Please Help.
Hopefully these equations will help. If you get stuck just reply.
V = Voltage (Volts)
I = Current (Amps)
R = Resistance (Ohms)
P = Power (Watts)
V = IR (Ohm's Law)
I = V/R (Ohm's Law Rewritten)
P = VI
P = V2/R
P = I2R
Keep in mind, the internal resistance of the battery can be modeled as a resistor in series with an ideal voltage source.
Draw a circuit diagram with the external and internal resistor.
You have a voltage divider there don't you?
And you know Power = I2R
