Shear stress calculation for adhesive
To calculate the maximum shear stress for a single lap joint with surfaces subjected to a downward force, the appropriate formula is stress = F/A, as the force is parallel to the joint. The formula VQ/Ib is more applicable to beams under bending stresses rather than shear in adhesive joints. For the cardboard sheets in question, using F/A will provide an average shear stress, which is often considered sufficient for design purposes. While shear stress may be concentrated near the load application, the uniform distribution assumption is typically accepted in practice. Thus, F/A effectively represents both the average and maximum shear stress for this scenario.
sonani_deepak
I want to calculate the maximum shear stress, that two surfaces joint by a single lap joint, would be able to take.
I am going to suspend one surface from a rigid supoort and then put the force on the other surface downwards using weights.
I am assuming that material will be able to take the stress before the joint breaks up.
My question is that, for max. shear stress, do i still use stress = F/A ? or something like
stress = VQ/Ib. I posted this question because I think the Force here is parallel to the joint and NOT perpendicular to it.
Note that the surfaces are merely 0.05 inch sheets of cardboard.
Also, would that give me the max. stress or the avg. stress? and if its just the avg. stress, what should i do to calculate max. stress?
Thnx in advance.
Thnx in advance.
The shear stress in your case, with the force parallel to the plane, is just F/A. The shear stress formula VQ/It applies primarily to beams subject to bending stresses, in which case this is the max stress in the beam, while the average stress may be approximated by V/A. But back to the case at hand, for your glued surface subject to shear without bending, it is common practice to consider the shear stress, F/A , as the average and max shear stress, that is, a uniform shear stress distribution across the entire glued surface. In actuality, the shear stress tends to concentrated higher in the area closer to the load application, but such max stresses are generally not considered in design, since the F/A formula works out quite well.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
