Solving Questions on Throwing a Baseball to Hit a Target
  • Thread starter Thread starter Sassenav22
    Baseball
To hit a target 10m away from a 25m high building, the baseball must be thrown horizontally at a velocity of 4.42 m/s, calculated using the time it takes to fall 25m under gravity. For a 45-degree launch angle, the horizontal and vertical components of the velocity are equal, leading to a more complex calculation involving both components. By substituting the time derived from the horizontal distance into the vertical motion equation, the vertical component is found to be 3.74 m/s. Consequently, the initial velocity required for the 45-degree throw is approximately 5.29 m/s. This analysis highlights the importance of understanding projectile motion in solving such problems.
Sassenav22
1. Homework Statement
You throw a baseball to hit a target on the ground 10m from the base of a building 25m in height. (a) With what velocity must you throw the baseball if it is to leave the hand horizontally? (b) with what velocity mut you throw the baseball if it is to leave the hand at a angle of 45 up from the horizontal? (c0 What is the horizontal component of the initial value o the velocity in case (b)?
(a) s=ut +1/2at^2
v=d/t
(b) i have no clue
(c) Vx(cos theta)
(a)s=ut+1/2at^2
25=0+ 1/2(9.8)t^2
25= 4.9t^2
25/4.9=t^2
t=√5.10
t=2.26s
v=d/t
= 10/2.26s
=4.42m/s
(b) i don't know can someone point me in the right direction
If it is thrown at 45° then Vx = Vy.
That means you can take your x and y equations and solve more easiily.
25 = Vy*t - ½gt²
10 = Vx*t
With Vx = Vy and t = 10/V ...
so its:
25=4.42(cos45)(t)+0.5(9.8)t^2
and solve for t
then use v=d/t
and find the velocity?
I'd just stick 10/V into the y equation for t and solve for Vx,Vy directly.
Then Vo = V/sin45 = Vx(√ 2)
i am confused
Since -25 = Vy*t - ½gt²
And |Vx| = |Vy| and
Vx = 10/t
Then Vy = 10/t or t = 10/Vy
Hence -25 = Vy*10/Vy - ½*g*(10/Vy)²
Simplifying 70V² = 100*g = 980
Vy = Vx = 3.74 m/s
Vo = 5.29 m/s
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
