Solve for Time in Air: Baseball Hit Problem | 30 m/s at 30 deg | Window at 12m
  • Thread starter Thread starter seraphimhouse
    Baseball
The discussion focuses on calculating the time a baseball is in the air after being hit at a velocity of 30 m/s at a 30-degree angle, starting 1 meter above the ground and needing to reach a window 12 meters high. The equation used is Y = Yo + Vot - 1/2gt^2, but there is confusion regarding the initial velocity (Vo) and initial height (Yo). The initial velocity should not be assumed as zero, as it is crucial for accurate calculations. The attempted solution yielded a time of 3.06 seconds, which does not match the book's answer, indicating a misunderstanding of the variables involved. Clarifying these variables is essential for solving the problem correctly.
seraphimhouse
After you hit a baseball, it flies into a window across the street. The baseball leaves your bat at a distance 1m above the ground, and the window is 12 m above the ground. The ball leaves your bat with a velocity of 30 m/s at 30 degrees.
How long was the ball in the air? Note: if your solution contains two roots, explain the meaning of each.
With that formula in #2. Vo = 0 m/s so Y = -1/2gt The magnitude of that gives me 3.06 s, but that does not correspond to the answer in the back of the book
Your attempted solution is not very detailed. Think about the meaning of each variable in the equation. You assumed Vo to be zero, but you know that stands for the initial velocity, right? Initial velocity of the ball is obviously not 0. Also Yo stands for initial height.
