U-shaped tube, pressure problem, what am i doing wrong?
  • Thread starter Thread starter jenzao
    Pressure Tube
In the pressure problem involving a U-shaped tube filled with water, the left side has an area of 0.05 m² and the right side has an area of 0.08 m², with the right side's water level being 0.43 m higher due to different forces applied by pistons. The force on the right side is given as 138 N, and the goal is to determine the force on the left side. The correct approach involves using the pressure difference created by the height of the water column, calculated using the formula P = ρgh, where ρ is the water density and g is the acceleration due to gravity. The extra pressure needed to lift the water on the left side corresponds to the height difference, which must then be multiplied by the appropriate area to find the force. The key is to ensure the correct area is used when calculating the force exerted by the pressure difference.
jenzao
What am I doing wrong in this pressure problem?
a U-shaped tube is filled with water.
left side area of opening is .05m^2
right side is .08m^2
the right side water level is .43m HIGHER than the left side, because two pistons push down on either side with different force on each side.
the force pushing down on right side is 138N
Q: What is the force pushing down on left side?
I know that P=F/A and also P= Pnaught + rho*g*h
so i rearrange to get F=PA
and P=rho*g*h (because i can factor out air pressure (Pnaught) because of the pistons,
so i now have F= rho*g*h*A
This is wrong though, and i can't figure out why, please help! thanks
You are looking for the extra pressure needed to make the side 0.43m higher
So you need the pressure to lift 0.43m of water, this is just the static pressure at the bottom of that extra water column.
The extra pressure on the input piston is the same as this - then to get the force just use the area - be carefu about which area you are using.
