Deriving Klein-Gordon from Heisenberg
waht
Sort of stuck deriving the Klein-Gordon equation from Heisenberg equation of motion
\dot{\varphi} = i [H, \varphi ]
\dot{\varphi} = \frac{\partial\varphi}{\partial t}
H = \int d^3x \mathcal{H}
\Pi (x) = \dot{\varphi}(x)
\mathcal{H} = \Pi \dot{\varphi} - \mathcal{L}
\dot{\varphi} = \int d^3x [ \dot{\varphi}^2 - \mathcal{L}, \varphi ]
if I expand that, then it becomes a real mess, not sure if I'm on the right track?
first, from the condition i*d(phi)/dt=[H,phi], you can arrive an equation, which makes [intgral(delta_phi)^2,phi]=0, then you differentiate the Heisenberg, equation, get d^2(phi)/dt^2=[H,[H,phi]], and substitute back. Then you get K-G equation immediately
\dot{\varphi} = i [H, \varphi ], we obtain
\int d^3x [ \delta{\varphi}^2, \varphi ]=0 Eq(1)
differentiate Heisenberg Eq. again, we have
\dot\dot{\varphi} = i [H, \dot{\varphi} ]=- [H, [H, \dot{\varphi} ] ]
substitute \Pi (x) = \dot{\varphi}(x) back,
using the specific form of H and use Eq.1, you'll get the answer of KG equation.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
