Rotational motion and law of gravity
The discussion centers on calculating the maximum angular speed of a neutron star, which has a mass twice that of the sun and a radius of 10 km, to ensure that surface matter remains in orbit due to gravitational force. Participants clarify that the gravitational force must equal the centripetal force acting on the matter at the star's equator. The correct equation to use is GMm/r^2 = mV^2/R, where variables represent gravitational force, centripetal force, and relevant constants. There is some confusion about including mass terms and determining what needs to be solved. The conversation emphasizes the importance of organizing given information to facilitate solving the problem.
wowdusk
Neutron stars are extremely dense objects that are formed from the remnants of supernova explosions. many rotate very rapidly. suppose that the mass of a certain spherical neutron star is twice the mass of the sun and its radius is 10.0 km. determine the greatest possible angular speed the neutron star can have so that the matter at the its surface on the equator to be just held in orbit by the gravitational force.
i no that the gravtiational force must equal the Force
so GM/r^2=mV^2/ R, but where do i go fom here I am lost!
...still lost... idk what to do...
So the gravitational force must equal the net force? Which is the centripetal force.
Fg=Fc
So I think you got this far already, but it looks as though you made a small mistake on this next step when you came up with this equation:
GM/r^2=mV^2/ R
You may have forgotten to either include a mass term or cross one out.. look at the equations for Fg and Fc again.
ok you so i get GMm/r^2=mV^2/R, but still don't know what to do
What is the question asking us to solve for?
Do you have everything you need to solve for it? I often make a list of everything that's been given, even before starting.
R=?
V=?
M=?
m=?
G=?
