Vector Planes & Orthogonality - Help
To find the unit normal to the plane defined by the equation x + 2y – 2z = 15, the normal vector can be directly derived as <1, 2, -2> without needing to calculate points and cross products. The user initially attempted to find the normal vector through points and vectors but encountered confusion with the signs in the cross product calculation. They realized that the normal vector's components can be directly taken from the coefficients of the plane equation. The discussion highlights the importance of recognizing the straightforward method of identifying normal vectors from plane equations. This understanding simplifies the process of determining orthogonality in vector planes.
mrneglect
Vector Planes & Orthogonality -- Help!
I must be doing something really stupid, and I'll kick myself when you point it out, but I'm having difficulty with this question:
Find the unit normal to the plane x + 2y – 2z = 15. What is the distance of the plane from the origin?
OK, so I know I need three points in the plane to identify it. I found points:
A = (15,0,0)
B = (15,1,1)
C = (13,2,1)
They all seem to satisfy the equation, right?
So now I find two nonparallel vectors in this plane:
A->B = 0i + 1j + 1k
A->C = -2i + 2j + 1k
They do indeed join those points, right?
So now I want to find an orthogonal vector, so I take the cross product by calculating the determinant of the 3x3 matrix:
[i j k]
[0 1 1]
[-2 2 1]
= (1-2)i - (-2-0)j + (0+2)k
= -i + 2j + 2k
This vector ought to be orthogonal to vectors A->B, A->C and B->C (and their negatives). But I try to test it with the usual method of adding up the parts and seeing if they result in zero, using A->C as my comparison vector:
(-2 * -1) + (2 * 2) + (1 * 2) = 8
Why doesn't this equal zero? I have a feeling that the middle (j) term is wrong, because if that was (2 * -2) then the whole thing would equal zero, but I don't see where I've got my signs wrong in the method.
Any help would be much appreciated.
Cheers!
mrneglect said:
[i j k]
[0 1 1]
[-2 2 1]
The second term in the sum should be -(0 - (-2))j = -2j.
Oh, I see, so it doesn't wrap around! That's probably why it's "+ i - j + k". Thanks for that. I knew it was something simple. :smile:
Actually, you should have learned early that if a plane is given by Ax+ By+ Cz= D, the <A, B, C> is normal to the plane. You don't need to do all that work. Since the plane is given as x + 2y – 2z = 15, you know that a normal vector is <1, 2, -2>.
Well for some reason that's not in our course, but I shall certainly be using it from now on!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
