Load Calc Analysis for a Ladder Frame - Get Help Now
  • Thread starter Thread starter the4thworld
    Analysis Frame
The discussion focuses on load calculations for a ladder frame chassis, specifically how vehicle weight at the center of gravity (Cg) is distributed along the frame and its effect on cross members. The user seeks guidance on performing these calculations without relying on analysis software. It is noted that uneven road conditions can create torque or twisting in the cross members, complicating the load distribution. A suggested approach involves using a dynamic amplification factor (daf) to determine weight distribution based on the distance of the Cg from the frame members and creating a free-body diagram for analysis. Detailed specifications such as dimensions and material properties are essential for accurate calculations.
the4thworld
Hey i would really appreciate it if someone could help me with the load calculations in a chassis.
The frame is basically a ladder frame, 2 C section side rails and cross members.
Would like to know how the weight of the vehicle acting at the Cg gets distributed along the frame. And how does this weight effect the cross members.
And apart from using an analysis software, how would i go about doing this.
Thanks
This is basically what the frame looks like
http://tinypic.com/r/20glmc1/5"
Almost 80 views and no replies??
Anyway
Considering the vehicle travels over uneven roads, thus causing one side rail to be lifted while the other remains the same, this would cause a torque or twist in the cross member.Any idea how i could go about calculating this??
the4thworld: You could assume the vehicle weight (multiplied by a dynamic amplification factor, daf) is distributed proportional to the distance of the CG from a member. Then you can draw a free-body diagram to analyze a particular member. However, your given question does not define where the vehicle weight would be applied to your four (or two) members, nor does it give dimensions, cross-sectional dimensions, material, wheel locations, nor daf.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
