Understanding Signal Distortion & Phase Shift w/ Resistor/Capacitor Circuits
  • Thread starter Thread starter jeff1evesque
    Signal
Capacitance and inductance in circuits cause different frequencies to experience varying levels of attenuation and phase shift, resulting in a received signal that differs from the sent signal. Low and high pass filters can be used to control which frequencies are allowed to pass through the circuit, affecting the phase of the output signal. In purely resistive circuits, the received signal is a scaled version of the input, indicating no distortion occurs. The phase shift in RLC circuits is determined by the relationship between voltage and current, where the presence of resistance allows for phase differences between 0 and 90 degrees. Understanding these principles is crucial for manipulating signal characteristics in electronic circuits.
jeff1evesque
Statement:
Capacitance and inductance in a circuit allow different frequencies to travel with differing degrees of attenuation and phase shift. This causes the received signal to be different from the signal sent.
Question:
With low and high pass filters, we can control what kind of signal continues to the remaining portion of the circuit by attenuating either signal at high frequencies or at low frequencies [by the construction of resistors and capacitors]. Can someone explain to me how one would change the phase of the signal sent; more specifically
Capacitance and inductance in a circuit allow different frequencies to travel with differing degrees of phase shift?
Statement:
In a purely resistive circuit, the signal received will be a scaled version of the signal sent \Rightarrow no distortion.
Question:
Does this mean the amplitude of the signal received will smaller? I am not familiar with the term distortion, does that mean the signal will have the same wavelength?
Thanks,
JL
jeff1evesque said:
Statement:
Question:
Statement:
The phase shift is the angle \phi between voltage and current in an RLC circuit. If the circuit does not contain resistance the phase difference will be + 90 or -90 (+- \frac{\pi}{2}. In order to have a phase difference of something in between you need resistance.
See, for example: http://en.wikipedia.org/wiki/Electrical_impedance
AM
That's all that's meant by it? Since we have a capacitor in the circuit, the wave that travels through the capacitor will have a voltage that is 90 degrees difference in phase? Is there any other implications- should the wave after going through the capacitor be 90 degrees out of phase with the wave coming into the capacitor?
Andrew Mason said:
In order to have a phase difference of something in between you need resistance.AM
So any kind of resistance will due (pure resistors, capacitors-with their impedance, inductors)?
Thanks,
JL
