What Is the Minimum Coefficient of Static Friction for a Ball Against a Wall?
To determine the minimum coefficient of static friction for a ball against a wall, the problem involves analyzing the forces acting on the ball, including tension and friction. The normal force is derived from the tension's vertical component, leading to the equation N = Tsinθ. The static friction force is expressed as uN, where u is the coefficient of static friction. By equating the torques from tension and friction, the relationship u = (1/sinθ) is established. To minimize u, it is essential to set the static friction force equal to its maximum value, ensuring that static friction does not exceed μN.
philnow
Here is a horrible diagram representing the problem:
The problem is to find the minimum coefficient of static friction between the ball and the wall so that the ball remains motionless.
torque = r*F
I've divided the tension force into x and y components, Tsinθ and Tcosθ respectively. Therefore the normal force (the wall pushing against the ball) is N = Tsinθ. The friction force is = uN = u(Tsinθ).
So now, because the ball is motionless, the two torques must cancel each other out. So Torque from the tension T(t) = (radius)*T and torque from the friction force T(f) = radius*Friction force = radius* uTsinθ. This gives u = (1/sinθ)... but I'm really not sure... also, how do I minimize this u?
Thanks in advance for any help.
Looks good to me. Setting the static friction force to equal to its maximum value μN (as you did) will give you the smallest μ. (Generally static friction ≤ μN.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
