[Work and Energy] Work positive or negative?
The discussion clarifies when the work of a spring is considered positive or negative, emphasizing that it depends on the spring's state. When a spring is compressed, external work is done on it, resulting in negative work by the spring. Conversely, when the spring is stretched, it does work on the external force, leading to positive work. The concept of sign convention is crucial, as negative work indicates that the spring opposes motion. Understanding these principles helps in applying the work-energy theorem effectively.
hiuting
I don't know when the work of a spring is negative, and when it's positive... When is the work of a spring negative and when is it positive?
Wsp= -(1/2)(k)(xf2-xi2)
I can get Wsp to be positive when the spring is stretch, but I want to know the theory behind it.
When does a spring oppose motion?
think about it in your everyday life pushing and pulling a spring
It's a sign convention. When a spring is compressed, something does work on the spring. So the work done by the spring is negative.
When the spring stretches, the spring does work on the 'something', so the work done is positive.
but negative work means opposing motion, therefore the spring always does negative work
