Magnets down a copper tube and Lenz's law.
Dropping a strong magnet down a copper tube induces a current that creates a resistive force, slowing the magnet's descent. The discussion explores how the number of magnets affects their falling velocity, with calculations linking the force on the magnets to their magnetic field strength and induced current. The force per magnet is derived from the relationship F=B^2VVol/ρ, where V is the velocity and Vol is the effective volume of copper. Experimental data suggests that as more magnets are added, the average velocity decreases, indicating that the changing shape of the magnetic field influences the induced current. The relationship between the number of magnets and their terminal velocity appears to be connected to the orientation of the magnetic field lines relative to the tube.
georgebarnett
Right. I know if you drop a strong magnet down a copper tube (or conductive but non magnetic tube) it falls slowly as it 'sees' a changing magnetic field and thus induces a current in the tube and this induced current causes its own magnetic field to be induced and acts a resistive force to the falling magnet.
But I've been trying to work out how the number of magnets (dropped as one body) is related to the velocity at which it falls. Could anyone help me with this one? I've been trying to work it out for ages but can't seem to get very far with it.
Thanks in advance for any help!
I’ll see if I can help.
Say your copper tube has an inside radius R and wall thickness D. Suppose R>>D. Say the (average) length of the magnetic field lines outside the magnet is H. Strength of magnetic field is B.
Then starting with the upwards force F on the magnet exerted by the currents I flowing in the tube:
F=BIL (I don’t know the name of this formula).
Induced currents I are running in 2 circles along the circumference inside the tube. One clockwise say for the north pole and ccw for the south pole, depending on which way the magnet is turned. The current density J is I/A where area A=D x H.
Then I=JxDxH
L is along the direction of the current so here: L =2pi R.
Put this back in F. F=BxJxDxHx2pixR. Now call DxHx2piXR=Volume=Vol.
This is the effective volume of copper occupied by B.
So: F=BJVol
Now J=E/ρ where rho is resistivity of copper and E is the electric field generated by BxV of the falling magnet. J=BV/ρ
Hence: F=B^2VVol/ρ. This the force per magnet. If you bundle some N magnets close together then H is the length of each magnet and F is multiplied by N. Also factor in an efficiency in of perhaps 70 to 80% because of field lines running in the air space between magnet and tube.
The electrical power P generated in the tube is: P=FxV=(B^2V^2Vol/ρ)x%. You can check this out because P is also I^2 x resistance.
The resistance is 2pixRxρ/HD.
I’ve never done this experiment so let us know if my calculations make any sense.
http://www.youtube.com/watch?v=30oPZO_z7-4&feature=related
This film confirms my calculations. Those small magnets can have magnetic B fields of up to 0.66 Tesla and with say a weight of 50 gram. If you put all that in the formula then V is very small say ~5 cm per sec.
Per Oni, thanks for you help. Your method makes sense but is not conclusive with my data. I think it may be easier if you see my data than me describing what I've found!
N V
1 0.568
2 0.279
3 0.269
4 0.264
5 0.318
6 0.370
N is the number of magnets, V is the average velocity (which equals terminal velocity - acceleration is negligible).
I think the relationship is to do with the changing shape of the magnetic field - with 3 or 4 magnets more of the field lines are perpendicular to the tube and thus a greater current is induced so a minimum terminal velocity is reached. What do you think?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
