Potentiostat the potentiostat circuit
  • Thread starter Thread starter raksha1405
    Circuit
A potentiostat circuit can be tested with an electrochemical cell, and a dummy load can be used to simulate this behavior. Electrochemical cells can be modeled using resistors and capacitors, where resistors represent conductive losses and capacitors represent the Helmholtz double layers. While a simple circuit can model basic functions of a battery or fuel cell, accurately modeling electrochemical devices often requires more complex equivalent circuits. For detailed modeling, resources like "Electro Impedance Spectroscopy" and related primers can provide valuable information. The discussion highlights the challenges in creating suitable equivalent models for specific applications, such as nerve stimulation.
raksha1405
Hi,
i don't even know if there is any solution to this... still trying my luck
i am working pn a project related to potentiostat
the potentiostat cirucuit needs to be tested with an electrochemical cell?
My issue is i am supposed to find an circuit which can behave like an electrochemical cell ( using a dummy load?)
Please let me knw if there is any circuit which behaves in the same way like an electrochemical cell
Thanks
All electrochemical cells can be closely modeled as resisters and capacitors. Resistors represent transport or conductive losses and capacitors can be used to represent the Helmholtz double layers for both anodic and cathodic electrodes.
For example, here is a very simple circuit that could be used to model a battery or fuel cell.
http://www.fuelcon.com/cms/uploads/RTEmagicC_GBZ1707_01_220_02.jpg.jpg
The above circuit may meet your requirements for your project but keep in mind that to accurately model most electrochemical devices, the equivalent circuits are actually quite complicated and require more than resistive and capacitive components. For more information on equivalent circuits, do a search for "Electro Impedance Spectroscopy".
Heres a good primer;
http://www.gamry.com/App_Notes/EIS_Primer/EIS_Primer.htm
I also have a similar problem. I have impedance data of an electrode which is being used for nerve stimulation and I want to make an equivalent model for it. I am using z view software to make an equivalent circuit but till now I have not succeeded in making a suitable model using my data.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
