What Are Some Electricity Questions That Involve Inductors and Capacitors?
  • Thread starter Thread starter bon
    Electricity
The discussion focuses on three main questions involving inductors and capacitors in electrical circuits. The first question addresses the time average of the product of current and voltage across an inductor, with the conclusion that the average is zero due to no power dissipation in purely reactive components. The second question involves sketching a waveform that combines two cosine functions with significantly different frequencies, confirming that it represents fast oscillations within a slower oscillating boundary. The third question pertains to finding the bandwidth of a signal expressed as a product of cosine functions, with the solution indicating that it can be simplified using trigonometric identities. Overall, the key takeaway is the behavior of inductors and capacitors in AC circuits and the mathematical relationships governing their interactions.
bon
1) Where I(t) = Iocoswt, and V' is the voltage across an inductance V' = L dI/dt, I am asked to work out the time average of <I V' >..
when i work it out, the answer comes to zero...any ideas why?
2)I'm asked to sketch I(t) = Acos(w1 t)cos(w2 t) where w2 << w1...
is this just fast oscillations of speed (w2) within a boundary that is itself oscillating (more slowly..) ? so a cos graph within a cos graph with bigger period?
3) Find the bandwith of the signal I(t) = A cos^2 (wt) cos(10wt)..
I know bandwith is the randge of angular frequencies present in I, but here its not just 10wt-wt is it? How do I work it out?
no ideas?
anyone?
No power is dissipated in a network with only inductors and capacitors.
yes
cos^2 (wt) is also a product of two cosines, so you can replace it with a sum involving
cos (0) and cos (2wt)
yes
Just a quick questionn about I = Acos(w1 t)cos(w2 t) one..
so w2 << w1 so would w2 be the outer shell, and w1 be the inner, fast oscillations.. how would you describe this?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
