Finding Acceleration: Motorist Travels 0.2km in 45-99km/h
  • Thread starter Thread starter adoado
    Acceleration
A motorist accelerates from 45 km/h to 99 km/h over a distance of 0.2 km. The initial calculation for acceleration using the formula v2 = u2 + 2as resulted in an incorrect value of 5400 m/sec². Participants suggest converting all units to meters and seconds before applying the formula for accuracy. The discussion emphasizes the importance of unit consistency in calculations. Proper unit conversion is crucial for obtaining the correct acceleration value.
adoado
A motorist enters a freeway at 45km/h and accelerates uniformly to 99 km/h. From the odometer of the car, the driver knows she has traveled 0.2km. Find the acceleration of the car.
I attempted this:
v2 = u2 + 2as
Substituting the values in I got this:
(992 -452)/0.4 = a
this gives 19440, so converting to m/sec I think I get 5400 m/sec2
This is definitely not right, any ideas why?
Cheers,
Adrian :)
What units do you think the 19440 would be in? Check your conversion.
The best thing to do is change units to m/s and m before you use them in the formula.
Got it! Thanks a bunch!
Cheers,
Adrian
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
