Working on high voltage power lines
Workers on high voltage power lines often work 'live' using specialized protective gear, including rubber gloves, but additional safety measures are necessary due to the extreme voltages. The gloves provide insulation, but they are not sufficient alone; workers also use insulated tools and wear dielectric boots to prevent electrical contact with the ground. The discussion highlights that birds do not get electrocuted on power lines because they are not grounded, which prevents a potential difference across their bodies. If a bird were to touch two wires simultaneously, it would create a dangerous situation due to the voltage difference. Overall, safety protocols are crucial for preventing electrocution when working on high voltage lines.
JJBladester
We know that current will flow whenever there is a potential difference. Sometimes when there are problems with high voltage lines - workers must work on them 'live' (not shut down). How do the workers manage to work on the wires without getting electrocuted by the high voltage?
N/A
If anybody knows how workers are protected in real life, I'd be curious to know.
I do know that if the workers had protective rubber gloves they would be okay to work on the wires because the gloves would insulate them against the flow of current. But, is there something else that high voltage workers use to not get 'zapped'?
N/A
Rubber gloves would not be enough by themselves at those voltages.
Here's a question for you that should help -- why don't birds get electrocuted when sitting on power lines?
Let's see... About the birds, they aren't grounded (obviously). That would mean that when they land on the power line, their potential would become that of the power line, meaning *somehow* they are not experiencing a net current...?
Not exactly. When you say "grounded", that would mean that they were holding a ground wire in one foot while holding onto the power wire with their other foot (no rubber booties). That creates a voltage (potential) difference across their little bodies, which generates a big current through them and poof!
But what if you had a big bird like a great white heron, who landed on the residential power wires, and had both feet on one wire. What would change when the heron tried to step to the next wire...?
And why would you not hand a metal tool to somebody working on a wire!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
