Finding Rate of Energy Loss in an RC Discharge Circuit
To find the rate of energy loss in an RC discharge circuit with R = 2.5 x 10^4 ohms, C = 40 microfarads, and an initial voltage of 25 V, the charge at time t can be calculated using Q = Q(initial)e^(-t/RC). The energy stored in the capacitor is given by U = 0.5 Q^2/C. To determine the rate of energy loss, the derivative dU/dt must be computed, which involves substituting Q(t) into the energy equation and differentiating. Evaluating this expression at t = 0.5 seconds will yield the desired rate of energy loss. This approach effectively combines the principles of charge decay and energy calculations in an RC circuit.
lha08
In an RC discharge circuit, R= 2.5 X10^4 ohms and C=40 microfarad. The initial potential difference across C is 25 V. Find the rate at which energy is being lost by C at 0.5 seconds.
Like in this case, I probably have to use Q = Q(initial)e^(-t/RC) and U= 0.5 Q^2/C. But then we need dU/dt...i'm not sure what to do...like i can solve for the charge at t=0.5 seconds and also the current if that matters...but like how am i supposed to use dt?...I've been stuck on this problem for like an hour...
Put Q(t) that you know in the equation for U, then take the derivative. Evaluate the expression that you get at t = 0.5 s.
