Young experiment in gravity field
helix
The current Young optical experiment induces interference between 2 waves when the two intermediary holes are opened and interference dissapears as soon as an active detection system is used to know by which hole the particle flied thru.
Surprisingly, even when particles are sent one to one the interference is maintained since it is not a statistical effect but the interference of the "quantic evolution wave" with itself.
But what if a not-active detection system were used ?
Typically considering that the two holes of the screen are not at the same height in a gravitational filed . The effect is light but the mossbauer shift of frequency related to relativist effect changes slighlty the frequency of the light and the influence of the hole number by which the particle fly thru could be detected.
What is your viewpoint about this possibility ?
You detect the particle in specific points, where the frequency from both paths will be the same again.
Interesting. But It would mean that particles will be detected even if you don t have any active interaction with the beam. If you have a free interference the fringe would be modify by the shift frequency depending from the height in the gravitational pit.
To detect the particle in specific points, where the frequency from both paths will be the same again would mean that we would not have any detection since the frequency are shift from one way to another.
But beyond the exchange do you know if the experiment was made ?
How so?
If you have [...] interference the fringe would be modify by the shift frequency depending from the height in the gravitational pit.
Yes.
I don't understand this sentence, and believe it is wrong.
I don't know.
It is a reasonable idea. Here is a practical issue: you can make "weak" measurements on particles in such a way that interference is only slightly degraded. If you then turn up the intensity of the measurement, the interference falls off accordingly. So a weak field like gravity likely wouldn't produce enough effect to do much.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
