How fast must a Puma leave to ground to go 12 feet high?
  • Thread starter Thread starter Physically Impaired
    Ground
To determine the speed a Puma must leave the ground to reach a height of 12 feet at a 45-degree angle, the discussion emphasizes the need to apply kinematic formulas for projectile motion. The trajectory can be analyzed using the equation for parabolic motion, considering both vertical and horizontal components separately. At the peak height, the vertical component of velocity will be zero, which is a crucial aspect of the calculation. The conversation highlights the importance of understanding the relationship between angle and velocity in projectile motion. Overall, applying these principles will lead to the correct solution for the Puma's launch speed.
Physically Impaired
This seems like an easy problem but without "time" i"m confused.
The best leaper is a Puma that can jump to a height of 12 feet when leaving the ground at a 45 degree angle. With what speed in SI units must the Puma leave the ground to reach this height?
I'm not sure what formula to apply since there isn't any time mentioned.
This is interesting.. because cos(45^o) = sin(45^o) :smile:
Do you know the formula's for the two dimensional movement under the gravity-force. You have a formule that describes the trajectory (a parabole) y = f(x). Now since the angle is 45° you can calculate all you need using this formula. There is another option when you use the x and y components for the position and velocity. Keep in mind that the y-component of the velocity is zero at the point of maximal height...
bonne chance
regards
marlon
Correct. Almost always in projectiles you must consider the vertical and horizontal components of the trajectory of an object separately. You can solve this problem using marlon's hints, kinematics formulas, and physical thinking. :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
