Surface Charge Density for Infinite Sheet of Charge
An infinite sheet of charge with a surface charge density of +7.8 micro-Coulomb/m² is positioned on the x-axis, while another sheet with an unknown charge density is on the y-axis. A positive point charge in the first quadrant experiences a total electric force directed at a 143-degree angle from the positive x-axis. The calculations indicate that the surface charge density of the sheet on the y-axis is -10.35 micro-Coulomb/m². Corrections in the direction of the electric field vectors are necessary for accurate results. Understanding the relationship between the charge densities and the angles is crucial for solving the problem effectively.
eestep
An infinite sheet of charge with a surface charge density of +7.8 micro-Coulomb/m2 lies on x-axis (technically in x-z plane). Another infinite sheet of charge with an unknown charge density lies on y-axis (technically in y-z plane). A positive point charge is placed in first quadrant and total electric force on this charge due to infinite sheets is directed at an 143 degree angle when measured counter-clockwise from positive x axis. What is surface charge density of sheet on y-axis in micro-Coulomb/m2? Answer is -10.35.
\sigma=dq/dA
Fex=-qE=-q\sigmax/2\epsilon0
Fey=qE=q\sigmay/2\epsilon0
tan\theta=(q\sigmay/2\epsilon0)/(q\sigmax/2\epsilon0)
tan\theta=\sigmay/\sigmax
\sigmay=\sigmaxtan\theta=7.8tan143
Does it not cancel anyhow?
\sigma=dq/dA
Fex=-qE=-q\sigmax/2\epsilon0 This should be Fey .
Fey=qE=q\sigmay/2\epsilon0 This should be Fex .
The sheet with known charge, lying in the x-z plane, produces an electric field parallel to the y-axis.
How do I calculate surface charge density of sheet on y axis?
The vector you said was in the x direction is in the y direction.
The vector you said was in the y direction is in the x direction.
Correcting this will give you the right answer.
I appreciate your assistance!
