Particle Motion in One Dimension
Two bodies in free fall from the same height, with one starting 1 second later, will be 10 meters apart at a certain time after the first body begins to fall. The equation x = x0 + vt + 1/2at^2 is used to describe their motion, where x0 represents the distance traveled by the first ball after one second. The distance between the two bodies increases as the first ball always has more speed due to its head start. By calculating the distance traveled by the first ball after one second and setting up the equation for their separation, the time can be determined. The solution involves solving for t and adding the initial second when only the first ball is in motion.
vsc
Two bodies begin a free fall from rest from the same height. If one starts 1.0 s after the other, how long after the first body begins to fall will the two bodies be 10 m apart?
x = x + vt +1/2at^2
I'm having trouble visualising a solution.
how did you get this equation:
x = x + vt +1/2at^2
This equation gives t = 0, t= -2v/a, none make any sense.
I will describe the situation.
The first ball would have traveled some distance at the time the second ball is thrown. Also the first ball would always have more speed than the second ball in their free fall situation. So the distance between them always increases. You need to find when it will be 10 m.
Calculate the distance traveled and final velocity of the first ball after 1 second using the formula you stated.
x = x0 + vt +1/2at^2
Where x0 is the distance traveled by the first ball after one second. Now you are looking for a distance of 10m apart, so the distane traveled by the first ball x1 is 10m further on than the distance traveled by x2.
And since the initial speed and position of ball two is zero
x1 - x2 = x0 +vt +1/2at^2 - 1/2at^2
note the acceleration term canceled as both balls accelerate at the same rate.
10 = x0 + vt
Solve this for t and add on the first second when only one ball is falling.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
