What are the unknowns in this nuclear reaction sequence?
The discussion centers on determining the unknowns X and Y in a nuclear reaction sequence involving nitrogen, hydrogen, oxygen, and fluorine isotopes. Participants agree that Y is likely a positron (e+) to balance the equation, referencing Soddy's Law for protons and nucleons. There is uncertainty regarding X, with suggestions that it cannot be a gamma photon due to binding energy considerations. The conversation highlights the complexities of decay processes, particularly the electron capture of fluorine-17, which adds to the confusion about the reactions. Overall, the participants seek clarity on these nuclear reactions and the implications of energy balance.
AStaunton
Hi there
problem is:
given the following nuclear reaction sequence, determine X and Y:
_{9}^{15}N+_{1}^{1}H\rightarrow_{8}^{16}O+\gamma
_{8}^{16}O+_{1}^{1}H\rightarrow_{9}^{17}F+X
_{9}^{17}F\rightarrow_{8}^{17}O+Y+\nu_{e}
My Attempted answer is:
As far as I can see, Y must be a e^{+} in order to balance with the \nu_{e} in the equation. But I am in doubt about this as the above way I am think is beta+ emission, however I read that the way of decay of fluorine-17 is electron capture so I don't know how to reconcile this.
Regarding what X is, I am not sure...I do not think it can be a \gamma as binding energy per nucleon of oxygen 16 is greater than that of fluorine 17..I don't see how it can be a lepton as the lepton number seems to be balanced already...
Any feedback on my queries for X and Y is appreciated
AStaunton said:
Hi there
problem is:
Hi !
I agree with Y must be a e^(+) (positron).
Because with Soddy's Law you have: For protons: 9 = 8 + Y + 0 <=> Y = 1
And for nucleons you have: 17 = 17 + Y + 0 <=> Y = 0
It's a positron !
Try to use my method.
Good luck ! :D
Extra energy can be supplied by kinetic energy, since the H impinges on the O.
