SH driven oscillator amplitude at resonance equation
The discussion revolves around the relationship between oscillator amplitude and mass at resonance, highlighting a contradiction with traditional horological practices. A participant notes that substituting the resonance frequency into the amplitude equation reveals a dependence on mass, which contradicts the belief that amplitude should be independent of mass. Another contributor acknowledges this finding but points out that the effect of mass on amplitude is minimal and counterintuitive. The conversation also touches on the complexities of applying standard differential equations to real-world pendulum clocks, where driving forces are not sinusoidal. Overall, the participants agree on the formula but express skepticism about its practical implications in horology.
bgc
I found via this forum the hint to use the inverse squared equation to differentiate to find the resonance frequency from the amplitude equation (equilibrium not transient solution). Thank you! (AlephZero?)
When substituting the resulting frequency for the resonance into the amplitude equation, I find the amplitude is a function of the mass of the mechanical oscillator. This violates centuries of horological experience!
bgc
p.s. Amp. (at resonance) = F/m / [dissipation constant/m * {W(0)^2 - (d.c./(m*2)^2)}^0.5]
The first two m's cancel (good), but there is another, bad! [The dissipation constant /m is the coefficient of the speed term in the driven damped (linear) harmonic oscillator differential equation; F is the amplitude of the sinusoidal forcing function]
I've just checked your amplitude at resonance and agree with you except for a factor of 2 in the second term under the square root in the denominator. This may well be a slip on my part. In any case, I don't think it affects the point you're making.
First thing: this second term is usually very small compared with \omega02.
But you think there should be no dependence at all on m?
I can't see anything wrong with such a dependence. For example, m certainly affects the half life of ordinary damped shm. A wooden pendulum of the same size and shape as a lead pendulum will take a shorter time to lose (say) half its amplitude. And I don't understand your reference to centuries of horological experience. Can you be more specific?
P.W.!
Horologist have tried to increase the amplitude of a 'failing" clock by adding mass to the bob. I didn't believe a friend's claim the amplitude was independent of bob mass. So I reviewed the differential equation and solution. The m's cancelled. Then a friend gave me an electromagnetic clock drive and I verified the analytic conclusion.
Description here:
http://www.cleyet.org/Pendula, Horo...; Energy Stored vs. Dissipation corrected.pdf
bc
p.s. it's difficult to compare various authors solutions (equations), because there is no standard differential equation.
The factor of 2 was indeed a slip on my part. I agree completely with your formula. One interesting point is that increasing m actually decreases the amplitude at resonance. Have to admit I find this counterintuitive. But then, of course, it is a very small effect. So much so, that I wouldn't have thought that changing the mass of the pendulum in a clock would make any significant to its amplitude - at least not due to the effect given by the formula.
Of course, in a traditional escapement-driven pendulum clock, the driving force is far from sinusoidal, and it depends to some extent on the pendulum's amplitude, so we can't apply the formula with any confidence, especially if we're thinking of small effects such as the one we've been discussing.
Thanks for the link: some interesting experimentation.
Sorry not to have helped. I'm sure you know much more about theoretical and practical horology than I do.
Au contraire! You confirmed and did help.
bc more later?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
