Work Done By Stretching a Steel Wire
The discussion revolves around calculating the stretch of a steel wire when a fish is hung from it and the work done during its downward motion. The initial calculations for the stretch and work done by gravity were found to be incorrect, with the correct stretch being 0.00162 m. The use of Young's Modulus and the spring constant was debated, with concerns raised about the professor's guidance on calculating the spring constant, k, multiple times. The importance of using the correct displacement from the wire's prestressed length for potential energy calculations was emphasized. The conversation highlights the need for careful application of physics principles in solving such problems.
ehralley
An angler hangs a 5.50 kg fish from a vertical steel wire 1.30 m long and 4.32×10^-3 cm in cross-sectional area. The upper end of the wire is securely fastened to a support.
Calculate the amount the wire is stretched by the hanging fish. (I found this to be 8.11x10-4 m)
The angler now applies a force F to the fish, pulling it very slowly downward by 0.569mm from its equilibrium position. For this downward motion, calculate the work done by gravity. (I found this to be 3.07x10^-2 J)
For this downward motion, calculate the work done by the force F.
E=FL_0/A_0ΔL
W=Fd
My prof reccomended using: k=EA_0/L_0 and W=0.5kx^2
Using Young's Modulus, F=EA_0ΔL/L_0
F=(2x10^11 N/m)(4.32x10^-7 m ^2)/(1.300811 m)
Solving for F=37.8 N
W=Fd
W=(37.8 N)(0.000569 m)
W=2.2x10^-2 J
Then I emailed my prof and he said to do it like this:
k=EA_0/L_0
k=(2x10^11 N/m)(4.32x10^-7 m^2)/(1.300811 m)
k=66420 N/m
W=0.5kx^2
W=(0.5)(66420 N/m)(0.000569 m)^2
W=1.08x10^-2 J
According to Mastering Physics, both of these answers are wrong. Please Help!
The stretch done by the freely hanging fish comes out to .00162 m. Your answer is off by a factor of two, and I'm wondering if you forgot to divide by .5 somewhere.
You correctly calculated the work done by gravity (during angler stretching).
Your prof then says to do this:
At this point I must question if he/she is really a prof and really not just a T.A. What he or she has done is to ask you to calculate a SECOND value for k - for k, the spring CONSTANT! The same spring should not have two different values for k. When doing this problem, the distance used in calculating the potential energy should always be measured as the displacement from the wire's prestressed length of 1.30 m. Then you're going to need to subtract from this the work done by gravity calculated using the total displacement.
Give it another try and give up on the idea that the "prof" is always right.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
