Thickness of steel required for a vacuum chamber
To build a vacuum chamber for chemistry, the design involves a prism structure measuring 24" wide, 18" deep, and 18" high, with a Plexiglas window. The walls will be made of galvanized steel, needing to withstand significant pressure, with the front, back, top, and bottom requiring support for 6480 pounds each, and the sides for 4860 pounds. Calculating the necessary thickness involves treating each side as a flat plate under normal load, using formulas for 2D elastic deformation. It's crucial to ensure that the maximum stress does not exceed the yield stress of the materials used, incorporating a safety factor. Understanding these calculations will facilitate moving forward with the project.
Upsilon
I'm trying to build a vacuum chamber for chemistry purposes. This isn't exactly for school, but it's something I'm doing for fun and it's close enough to a school problem. Anyway, my vacuum chamber will be a prism 24" wide, 18" deep, and 18" in height. It will also have a 8"x6" Plexiglas window on top. Obviously, a large amount of pressure will have to be dealt with. The walls of the chamber will be galvanized steel. Assuming about 15 PSI at sea level (I live in Florida), the front, back, top, and bottom (24"x18" each) must hold up to 6480 pounds each, and the left and right sides (18"x18" each) must hold up to 4860 pounds each. The Plexiglas window must also hold 720 pounds on its own.
Now, I've spent several hours trying to figure this out on my own, but it's just become too much of a headache and I have no idea where to start trying to solve this. Basically, I want to know how thick the steel/Plexiglas has to be to withstand the above forces. Or perhaps you could give me some formulas and whatnot to get me started. I'd really just like to get past this so I can start on the fun stuff.
Thanks,
υ
Treat each of the 6 sides as a flat plate simply supported on the edge, with no tension normal to the edge (i.e., on a roller), and loaded normally. Look up the solution for the 2D elastic deformation of a flat plate, and make sure that the plate is thick enough such that the maximum stress does not exceed the yield stress of the material. Also apply a reasonable factor of safety to be sure.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
