Forces necessary to hold a board steady (double check my work?)
The discussion revolves around calculating the forces required to hold a board steady, using equations for equilibrium. The user initially calculated a negative value for B, which was corrected to a positive 477.4 N after re-evaluating the equations. The calculations for Fx and Fy were also adjusted, yielding values of 238.7 N and 27.6 N, respectively. Participants confirmed that the method used was appropriate and that the resulting numbers were reasonable. The consensus emphasizes the importance of ensuring that the net force is zero while recognizing that individual force components may not be zero.
Lotus93
This is the problem:
http://oi47.tinypic.com/6qij4o.jpg
I set fx, fy, and B equal to zero.
'x' forces: Fx - Bsin(30) = 0
'y' forces: Fy - mg + B(cos(30)) = 0
lower end: -0.5*mg(cos(30)) + 0.4*B = 0
Using the third equation I solved for B, and got -477.4.
I then plugged B into the first two equations and calculated Fy=854.4 and Fx=-238.7.
I don't feel confident in these numbers, so I wanted to double check with someone who has a better understanding. Did I go wrong somewhere, or does this look okay?
Thanks in advance, I really appreciate your help.
Why set all those to zero?
B should be positive !
I set them equal to zero because I thought the net force should be equal to 0 in order to hold the board still... is that wrong?
This is what I have now...
(-0.5)(m)(g)(cos(30))+(B)(0.4)=0
B=-(-.5)(45)(9.8)(cos(30))/0.4
B= 477.4
Fx-B(sin(30))=0
Fx=(477.4)(sin(30))
Fx= 238.7
Fy-mg+B(Cos(30))=0
Fy=-477.4(Cos(30))+(45)(9.8)
Fy=27.6Am I anywhere close to being right?
The net force is zero, but that doesn't mean that each individual component making up the net force is zero.
B= 477.4
Fx-B(sin(30))=0
Fx=(477.4)(sin(30))
Fx= 238.7
Fy-mg+B(Cos(30))=0
Fy=27.6
The method is right.
The numbers look reasonable.
Of course, all of those answers are in units of Newtons.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
