Using Maxwell Boltzmann distribution to find number of atoms
The discussion focuses on calculating the number of mercury atoms in the first excited state using the Maxwell-Boltzmann distribution. The energy difference between the ground state and the first excited state is given as 4.86 eV, with a sample containing 1.06×10^20 atoms at 1563 K. The participant successfully normalized the distribution and determined the constant A to be 3.854. They also identified the statistical weights for the ground and excited states, noting 2 states for n=1 and 8 for n=2. The participant ultimately resolved their confusion regarding the integration limits needed for the calculation.
dinospamoni
You will recall from our discussion of the Franck-Hertz experiment that the energy difference between the first excited state of mercury and the ground state is 4.86 eV. If a sample of mercury vaporized in a flame contains 1.06×1020 atoms in thermal equilibrium at 1563 K, calculate the number of atoms in the first excited state. Assume that the Maxwell-Boltzmann distribution applies and that the n = 1 (ground) and n = 2 (first excited) states have equal statistical weights.
The Maxwell-Boltzmann distribution:
f(E)=A e^{\frac{E}{k_{b}T}}
where A is a constant
k_b is the Boltzmann constant = 8.617*10^-5 eV/K
and T is the temperature
n(E)dE = g(E) * f(E) dE
where n(E) = # per unit energy
g(E) = # of states per energy E
f(E) = MB distribution
I'm still having trouble learning how to use distributions, so bear with me (or help me understand it :))
I started off by normalizing the distribution by:
\int\limits_0^\infty f(E)^2 dE
then I set it equal to 1 and solved for A. I found A=3.854.
I think that was the right first step.
and I know that g(E) for n=1 is 2 possible states
and n=2 has 8.
This is as far as I have gotten, as my professor hasn't really gone over how to use these distributions.
My guess is that I set
1.06*10^{20} = n_{1}(E) dE + n_{2} (E) dE <br /> <br /> after this I know I have to integrate, but I'm not sure how to set up the limits, among other things.
never mind I figured it out!
