Calculating Total Mass of Nitrogen in Atmosphere
To calculate the total mass of nitrogen in the atmosphere, the correct approach involves using the mass of the atmosphere and the percentage of nitrogen by volume. The initial calculations included converting the mass of the atmosphere to liters and applying the ideal gas law, but discrepancies arose in the final mass of nitrogen obtained. The density of air and nitrogen at standard temperature and pressure (STP) is crucial for accurate calculations. The mass of nitrogen can be determined by multiplying the mass of the atmosphere by the massic concentration derived from the densities of air and nitrogen. Following this method yields the correct total mass of nitrogen in the atmosphere.
gunnar
Hi. Can someone give me a hint to how to calculate total mass of nitrogen in the atmosphere. I've calculated the mass of all the atmosphere, I got the percent by volume of nitrogen to be 78.03 %. I converted the mass of the atmosphere to Liters. I got the volume of nitrogen to be 3.18e21 L and converted to 3,099 e18 kg. The correct answear is 3,96e18 kg can't see what I doing wrong. To get the Kg of nitrogen I used the partial pressure of N2 in O°C and the gas equation to get the moles of N2. Maybe I'm getting the partial pressure wrong. I did 78.03/100 = 0,7803*1 atm
I'm not completely sure, but I'd suggest using the old PV=nRT, using the volume of the atmosphere, along with the average partial pressure of Nitrogen.
U need the density of air and the density of gaseous nitrogen under normal conditions of pressure & temperature.
100l air------------------------x Kg air
100 l air----------------------78.03 l N_{2}
78.03 l N_{2}----------------- y Kg N_{2}
Therefore the massic concentration of N_{2} is y/x...
Multiply the massic concentration with the mass of the atmosphere & u'll find the mass of N_{2}
Daniel.
Thanks Daniel. I did what you told me, if I got it right I still didn't get the right answear. Calculated the density of air and N2 in STP multiplied by 100 and 78.03 respectively. the difference was about 0.5 something. multiplied with the mass of air whis is 5,266e18 Kg. Should get 3,96e18 Kg got 3,01e18 Kg
The density of air under normal conditions of pressure & temp.is
\rho_{air}^{STP}\simeq \frac{28.89}{22.41} Kg \ m^{-3}
The density of nitrogen under normal conditions of temp & pressure is
\rho_{N_{2}}^{STP} \simeq \frac{28}{22.41} Kg \ m^{-3}
So 22.41 l of air contain 28.89 \cdot 10^{-3} \ Kg of air.Now,22.41 l of air contain 78.03% N_{2} which means exactly
\frac{22.41\cdot 78.03}{100} \ l _{N_{2}}
The mass of N_{2} in 22.41 l air is
mass_{N_{2}}=\frac{22.41\cdot 10^{-3} m^{-3} \cdot 78.03}{100}\cdot \frac{28}{22.41}Kg \ m^{-3}=\frac{28 \cdot 78.03 \cdot 10^{-3}}{100} \ Kg
The massic concentration is
n_{massic}^{N_{2}}=\frac{28\cdot 78.03 \ 10^{-3} \ Kg}{100} \frac{1}{28.89 \cdot 10^{-3} \ Kg} =\frac{78.03}{100}\cdot \frac{28}{28.89}
Then the mass of N_{2} in the atmosphere under normal cond-s of temp & press. is
m_{N_{2}}^{atmosphere,STP} =m_{atmosphere} \cdot \frac{78.03}{100}\cdot\frac{28}{28.89}
Daniel.
It works. Thanks a lot
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
