Parallel Plate Capacitor with Dialectric
To determine how much charge can be placed on a capacitor with air between the plates before breakdown occurs, one must understand the concept of dielectric strength. The dielectric strength of air is the minimum electric field that causes it to become conductive. To solve the problem, calculate the charge that produces an electric field equal to this dielectric strength using the capacitor equations provided. The dielectric constant of air can be approximated as 1 for this calculation. Knowing the dielectric strength value is essential for finding the maximum charge before breakdown.
AdkinsJr
How much charge can be placed on a capacitor with air between the plates before it breaks down if the area of the plates is 5 cm^2.
C=\frac{Q}{\Delta V}
C=kC_o
C=k\frac{\varepsilon _o A}{d}
Where "k" is the dialectric constant.
I'm not sure where to begin with the equations I know, I also don't know what is meant by "breaks down," how to interpret it mathematically; and I feel like I don't have enough information to solve the problem. Any help appreciated...
If the electric field gets too strong, the dielectric material (air in this case) can "break down" and become conductive. See this short video. The minimum electric field that will cause a material to break down is called the "dielectric strength" of the material. To work this problem you will need to know the dielectric strength of air. If you are using a textbook, you can probably look up the value there.
So, essentially, you need to find the charge on the plates of the capacitor that will produce an electric field equal to the dielectric strength of air. (The dielectric constant, k, of air can be taken to be 1 for this problem.)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
