Uniform Probability over Real Line?
gajohnson
Consider a two-ended laser spinner; that is a pen-like laser acting as the arrow mounted on a pin at the center of a spinner. Suppose the center of the disk is one meter away from a wall of infinite extent marked with a linear scale, with zero at the point closest the center of the spinner and negative numbers to left, positive to the right.
The laser is spun and comes to a rest projecting for one of its ends at a point Y on the
scale (with probability zero the laser will stop parallel to the wall and miss it; we ignore
that possibility). Suppose that the angle X the laser makes to the perpendicular to the
wall is uniformly distributed over –π/2 to π/2. Find the probability density of Y.
The angle at which the laser lands must have PDF f_X(x)=1/{\pi}
That is, it is the uniform distribution over pi radians.
Next, I set up a right triangle and find that the angle opposite the the 1 meter side is equal to {\pi}/2-X and that the angle opposite the base (call it B) is simply X (given by the PDF above). Using the law of sines (and that the distance from the "infinite wall" to the spinner is 1 meter) to find:
B=sinx/sin({\pi}/2-X)
It seems clear to me that Y is then the uniform distribution over lim B as x->{\pi}/2 + - (lim B as x->-{\pi}/2)
This is the entire real number line and so the PDF of Y does not exist.
Is this right (even if my steps are less than rigorous)? Any help would be appreciated.
Let the origin of the Y axis along the wall be the foot of the 1 meter perpendicular side. Then for a point Y on that axis you have ##\frac Y 1 =\tan X##. Try starting with that.
Likes 1 person
So much simpler! My trig is too rusty.
Ok, so then I find that g(Y)=arctan(Y) and, after taking the derivative, I make the transformation assuming the uniform distribution described before for X.
I get f_Y(y)=1/{\pi}(1+y^2)
Is it that simple? Thanks!
Confirmed this elsewhere. It is indeed that simple. Appreciate your help!
Yes, it is. Sorry I couldn't get back to you yesterday. Too busy.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
