Proving the various forms are equivalent
  • Thread starter Thread starter embphysics
    Equivalent Forms
The discussion focuses on proving the equivalence of four representations of simple harmonic motion. The user successfully demonstrated that the second form follows from the first but is struggling to show that the third form derives from the second. They initially considered trigonometric identities and relationships between sine and cosine but found them unhelpful. A suggestion was made to use the angle sum formula for cosine to establish simultaneous equations relating the constants, ultimately leading to a solution for the variables A and δ in terms of B1 and B2. The goal remains to show that the third form can be expressed in terms of the second through proper manipulations.
embphysics
In Section 5.2 we discussed four equivalent ways to represent simple harmonic motion in one
dimension:
x(t) = C_1 e^{i \omega t} + C_2 e^{-i \omega t} (1)
= B_1 cos(\omega t) + B_2 sin (\omega t) (2)
= A cos(\omega t - \delta) (3)
=Re C e^{i \omega t} (4)
To make sure you understand all of these, show that they are equivalent by proving the following implications: I → II → III → IV → I. For each form, give an expression for the constants (C1, C2, etc.) in terms of the constants of the previous form.
I was successful in showing that (2) follows from (1). However, know I am endeavoring to show that (3) follows from (2).
At first, I thought that there might be some trigonometric identity involving the sum of two trig functions; but I couldn't not find any such identity. Then I tried to write the sine function in terms of cosine, noting that the sine function is shifted 90 degrees; this, too, did not seem very helpful. Finally, I noted that both trig functions has the same argument, from which I tried to draw a triangle, but immediately realized that this would be of no help.
Could anyone provide a hint?
dimension:
Expand (3) using the angle sum formula for cosine. Compare with (2). Set up a pair of simultaneous equations relating A and δ to B1 and B2.
To solve them for A and δ, there is a well-known trick using trig identities. First square the two equations and add. Remember that ##\sin^2\delta + \cos^2\delta = 1##. That should get you A quickly.
To solve for δ, divide the two equations, cancelling out A. Remember that ##\frac{\sin\delta}{\cos\delta} = \tan\delta##.
I am not sure that is correct. I need to show that (3) results from (2) through manipulations and definitions, not the other way around.
Currently A and δ are undefined in terms of B1 and B2. What you need to do is to show that you can solve for these variables in terms of the earlier ones. Then you *have* shown that (2) can be re-expressed as (3).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
