Calculating Max Height of Water Squirted from Garden Hose
To calculate the maximum height of water squirted from a garden hose nozzle, the projectile motion equations are essential. The nozzle's radius and the velocities of water in both the hose and nozzle are crucial for determining the height. The expected answers are 42 meters for the nozzle attached and 0.4 meters without it, indicating a significant difference due to the nozzle's effect on velocity. If the calculations are incorrect, reviewing the use of projectile motion equations is necessary. Proper application of these equations will yield the correct results.
narutoish
A nozzle with a radius of 0.250 cm is attached to a garden hose with a radius of 0.800 cm. The velocity of the water in the hose is 2.80 m/s and the velocity of the water in the nozzle is 28.7 m/s.s
(a) Calculate the maximum height to which water could be squirted if it emerges from the nozzle.
(b) Calculate the maximum height to which water could be squirted if it emerges with the nozzle removed, assuming the same flow rate.
I might be missing something but don't I only have to use the projectile motion equation and solve for the delta y?
I tried using the projectile motion equation but I don't get the right answer, and I don't know how to make use of the radius information.
The answers are supposed to be a) 42m and b) .4m I just need to know how it's solved
Those answers can indeed be obtained with just the projectile motion equations. If you cannot obtain them, you must be making a mistake somewhere. Show your work.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
