Question about relativistic energy
In the decay of a pion at rest into a muon and an antineutrino, the conservation of energy and momentum is crucial. The muon's kinetic energy is calculated to be approximately 2.095 MeV, derived from its mass and the relativistic energy equation. The antineutrino, having no rest mass, carries an energy of -2.095 MeV, indicating that it balances the energy of the muon in the system. The calculations utilize Einstein's energy-momentum relationship and the principles of relativistic physics. This analysis highlights the importance of energy conservation in particle decay processes.
andrew410
A pion at rest (m_pi = 273m_e) decays to a muon (mass = 207m_e and an antineutrino (mass = 0). Find the kinetic energy of the muon and the energy of the antineutrino in electron volts.
How am I supposed to start this problem? ANy help would be great...thx!
If the muonic antineutrino has no rest mass,then his energy & rel.momentum vector in modulus are linked through
E_{\bar{\nu}_{\mu}}=pc
The key point is that both energy (seen as the time component of the energy-momentum 4-vector) and relativistic momentum (seen as the space components of the energy-momentum 4-vector) are conserved.
Daniel.
P.S.Einstein's formula is E^{2}=m^{2}c^{4}+\left|\vec{p}\right|^{2}c^{2}.
To solve this problem, we can use the equation for relativistic energy: E = mc^2 / √(1-v^2/c^2). First, we need to find the velocity of the muon after the pion decays. Since the pion is at rest, its initial velocity is 0. We can use conservation of momentum to find the velocity of the muon:
0 = m_pi * v_pi + m_mu * v_mu
Since the pion is at rest, v_pi = 0. Solving for v_mu, we get:
v_mu = -m_pi / m_mu * v_pi = 0
Therefore, the velocity of the muon is also 0 after the pion decays. Now, we can plug in the values for mass and velocity into the equation for relativistic energy:
E_mu = m_mu * c^2 / √(1-0^2/c^2) = m_mu * c^2
Substituting in the given masses, we get:
E_mu = (207m_e) * (c^2) = (207 * 9.109 * 10^-31 kg) * (2.998 * 10^8 m/s)^2 = 3.358 * 10^-12 J = 2.095 MeV
To find the energy of the antineutrino, we can use the fact that the total energy of the system must be conserved. Since the pion was at rest, its initial energy is 0. Therefore, the total energy after the decay must also be 0. We can set up an equation to solve for the energy of the antineutrino:
E_pi + E_mu + E_antineutrino = 0
Substituting in the values for the masses and the energy of the muon that we just calculated, we get:
0 + 2.095 MeV + E_antineutrino = 0
Solving for E_antineutrino, we get:
E_antineutrino = -2.095 MeV
Since we are looking for the energy in electron volts, we need to convert the units:
E_antineutrino = (-2.095 MeV) * (1.602 * 10^-13 J/MeV) = -3.353 eV
Note that the negative sign indicates that the antineutrino
