Pressure across an orifice/choke plate
  • Thread starter Thread starter scienc
    Plate Pressure
To calculate the diameter of an orifice plate for restricting mass flow to 1.5 kg/s of compressed air at 400 psia and 300K, understanding pressure dynamics is crucial. When fluid flows through an orifice, total pressure does indeed drop due to energy losses, primarily from friction and turbulence, which are related to momentum losses. While static pressure decreases and velocity increases, the conservation of energy principle indicates that total pressure must also decrease. This relationship is essential for designing an effective choke plate. Clarifying these concepts will aid in achieving the desired flow rate.
scienc
Hi,
I've been trying to calculate the diameter for an orifice plate so that when inserted in a pipe it restricts the mass flow to the value I want (1.5 kg/s of compressed air, total pressure= 400 psia, T=300K). So essentially I am trying to design a choke plate. When a flow goes across an orifice plate, does the total pressure drop ? I can understand that the static pressure drops and velocity increases. But I simply can't get why the total pressure has to drop. Does it have something to do with momentum losses ?
Answering this would really help me sort out my confusion.
Thanks
N
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
