Eigenvectors of a 3x3 Matrix A: Calculation and Verification
  • Thread starter Thread starter Mathman23
    Eigenvector Urgent
The discussion centers on calculating the eigenvalues and eigenvectors of the matrix A = [[2, 1, 0], [0, 1, 0], [3, 3, -1]]. The initial eigenvalues calculated were (2, 1, -1), but a participant's third eigenvector was challenged, leading to a correction that the eigenvalue calculations were incorrect, yielding (0, 1, 2) instead. The zero vector is clarified as not being a valid eigenvector, and the need to adjust the matrix for accurate calculations is emphasized. The conversation also touches on finding an invertible matrix P that relates to the eigenvectors.
Mathman23
Hi
I have this here matrix
A = \left[ \begin{array}{ccc} 2 & 1 & 0 \\ 0 & 1 & 0 \\ 3 & 3 & 0 \end{array} \right]
I calculate the eigenvalues and get (2,1,-1)
Next I calculate the eigenvectors and get (1,0,1) and (-1,1,0) and (0,0,0)
My professor says my third eigenvector is wrong and it should (0,0,1)
My calculation:
A = \left[ \begin{array}{ccc} (2-(-1) &amp; 1 &amp; 0 \\ 0 &amp; (1-(-1) &amp; 0 \\ 3 &amp; 3 &amp; 1-(-1) \end{array} \right]<br /> = \left[ \begin{array}{ccc} 3 &amp; 1 &amp; 0 \\ 0 &amp; 2 &amp; 0 \\ 3 &amp; 3 &amp; 0 \end{array} \right]
Then according to the theorem regarding eigenvectors:
\left[ \begin{array}{ccc} 3 &amp; 1 &amp; 0 \\ 0 &amp; 2 &amp; 0 \\ 3 &amp; 3 &amp; 0 \end{array} \right] \left[ \begin{array}{c} v_1 \\ v_2 \\ v_3 \end{array} \right] = \left[ \begin{array}{c} 0 \\ 0 \\ 0 \end{array} \right]
then
3v_1 + v_2 = 0
2v_2 = 0
3v_1 + 3 v_2 = 0
Is my calculations correct ??
sincerley and best regards,
Fred
First of all, the zero vector is never an eigenvector (even though it might behave like one). If x is an eigenvector "belonging" to the eigenvalue -1, then Ax = -x, or equivalently (A + I)x = 0. The right-most entry in the bottom row of this equation:
is wrong, there should be a 1 there instead of a 0.
Check your eigenvalues again. I get \lambda = 0,1,2
Hi and many thanks for Your answer.
I have a second question I hope You can answer for me.
Finding a matrix P which is invertible and which complies with P^-1 AP ? ?
Isn't P then span of the three eigenvector ?
Sincerley and Best Regards,
Fred
Hi again
thats because I typed my matrix wrong
A = \left[ \begin{array}{ccc} 2 &amp; 1 &amp; 0 \\ 0 &amp; 1 &amp; 0 \\ 3 &amp; 3 &amp; -1 \end{array} \right]
Sincerley
Fred
