Is Converting Kgcm to Nm Correct?
  • Thread starter Thread starter Lorens
    Convert
The discussion clarifies that converting 1.28 Kgcm to Newton-meters (Nm) involves understanding the difference between mass and force units. Specifically, Kgcm is a torque measurement, while Nm is a force measurement. To convert Kgcm to Nm, one must first convert centimeters to meters, resulting in 0.0128 kgm. The confusion arises from mixing units of torque and force, as Kg is mass and N is force. Accurate conversion requires applying the correct factors for length and understanding the relationship between torque and force.
Lorens
We got 1.28 Kgcm
we turn cm to meter 128kgm
Then we turn it into Newton then we get about 1280NM
Problem is that i get some indication that this is wrong... is it?
(how do i get ride of overlay in explorer )
What's NM? And Kg m (or more generally Mass.Length) is not dimensionally the same as a Newton(Mass.Length.Time^-2).
It looks like one is trying to develop a moment and force or torque?
If 1.28 Kgcm = 1.28 kg-cm, then multiply by 1 m / 100 cm to to get 0.0128 kg m.
As neutrino pointed out, kg is a unit of mass and Nt (or N) is a unit of force.
1 kg * 9.8 m/s2 = 9.8 kg-m/s2 = 9.8 Nt or
0.102 kgf = 1 Nt.
For units conversion, here is a nice reference -
http://www.projects.ex.ac.uk/trol/scol/ccforce.htm for force
In general - http://www.projects.ex.ac.uk/trol/scol/index.htm
0.102 kgf = 1 Nt.
I am not intrsted in what to do, i am interested in what i am doing wrong, you say that 1kgcm is 0.01kgm, i don't get that. It is a torque for a motor.
This is a conversion of unit problem.
I was simply pointing out the to convert a length in cm to a length in meters, one multiplies by the a factor which relates the two.
for example 1 cm = 0.01 m, or 1 m = 100 cm. The conversion factor can be 0.01 m/cm or 100 cm/m.
If a torque is written in kgf-cm and one wishes to convert it to kgf-m, then one must multiply by 1 m/100 cm, and one will get
1 kgf-cm * 1 m/ 100 cm = 0.01 kgf-m.
