Liquid drop contact angle: THF, mica & graphite
The discussion centers on the search for experimental values of the contact angle between tetrahydrofuran (THF) and mica or graphite substrates. The user notes that THF wets these substrates well, indicating a very small contact angle, but acknowledges the challenge of obtaining measurements due to THF's rapid evaporation at room temperature. Despite extensive online searches yielding no results, there is a suggestion to consult the book by Adamson for potential insights. The user contemplates providing an estimated upper limit for the contact angle, emphasizing the need for a more precise characterization despite the inherent difficulties.
zeta101
This is a long shot, but maybe someone will know or can point me in the right direction. I'm looking for an experimental value for the contact angle between tetrahydrofuran (THF) with both mica and graphite substrates. I've done numerous googling and also did a search on the web of knowledge to no avail. I know the angle will be very small because THF wets both of those substrates quite well.
I suspect no measurements have been made however as THF evaporates in a matter of seconds at room temperature/pressure, but even so...
Thanks
Chemistry news on Phys.org
"... very small because THF wets both of those substrates quite well."
http://www.worldcatlibraries.org/wcpa/ow/631cd036ca9ca2e1a19afeb4da09e526.html
You're into "splitting hairs" over the differences between "six" and "half a dozen" here. Adamson might help you.
Thanks, I will check out the book. Indeed you are correct about splitting hairs, I'm thinking that it might be best to just state that the angle is very small, but I would like to put a upper limit on it, I may have to make an estimate somehow. I will still have a look in Adamson just in case, thanks again!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
