Why Does Enthalpy Decrease on Isothermal Compression?
  • Thread starter Thread starter sero2000
    Law Thermo
In an isothermal system, increasing pressure from 0 to 10 MPa causes a decrease in enthalpy due to the relationship between internal energy and volume. As the gas is compressed, the molecules have less space to move, which reduces internal energy. To maintain isothermal conditions, energy must be removed from the system, leading to a reduction in enthalpy. For real gases, enthalpy is pressure-dependent, unlike ideal gases, which complicates the relationship between enthalpy and pressure. Understanding these principles is essential for analyzing non-ideal gas behavior in thermodynamics.
sero2000
Basically I just want to know why if I increase the pressure from 0 to 10MPa in a isothermal system containing oxygen, the enthalpy will decrease?
Delta H = Delta U + delta PV
PV = nRT
PV = ZRT
During a tutorial, I was actually told that because of the compression, the compressed molecules will have less space to move around which results in a decrease in internal energy. Honestly I don't get it.
If I have a compression taking place, doesn't that mean Work is done on the system? Wouldnt that mean in order to keep the system isothermal, energy would have to be removed from the system? which results in enthalpy being reduced?
In that case and also because at 10MPa the gas is not ideal, I used PV = ZRT but I can't find the link between this and Delta H = Delta U + delta PV.
Any help in clearing this doubt is really appreciated :D
PV = nRT
PV = ZRT
Enthalpy is independent of pressure only for an ideal gas. For a real gas beyond the ideal gas region,
\frac{∂H}{∂p}=\left(V-T\frac{\partial V}{\partial T}\right)
Note, for an ideal gas, this is zero. There are generalized dimensionless graphs and tabulations in thermo books of the integral of this expression based on the corresponding states principal. You can use these to estimate the change in enthalpy for oxygen, from knowledge its critical properties. See Introduction to Chemical Engineering Thermodynamics by Smith and Van Ness.
Chet
