2-Resistor, 2-Capacitor Circuit with Switch
The discussion focuses on solving a circuit problem involving two resistors and two capacitors with a switch. The initial correct charge for one capacitor is 4.8 microC, but confusion arises regarding the charges on the capacitors when the switch is closed. It is clarified that the two capacitors cannot be combined into an equivalent capacitor due to the path created when the switch is closed. The textbook provides specific charge values for the capacitors: Q1 is 2 microC and Q2 is 16 microC. The participant expresses gratitude after resolving the confusion with the help provided.
Mark Zhu
In the circuit below, find the charges on the capacitors a) if the switch is open, b) if the switch is closed. Here C1 = 1 microfarads, C2 = 4 microfarads, R1 = 20 ohms and R2 = 40 ohms.
V = iR
Q = CV
I already did part a and got the correct answer of 4.8 microC. However, I am unsure how to approach part b, where the switch is closed and apparently the two capacitors end up with different charges. For part b, since there is a path between the two capacitors, I don't know if I am able to combine the two capacitors into an equivalent capacitor. According to the textbook, the solution is that Q1 is 2 microC and Q2 is 16 microC. Any help is appreciated.
Hi,
Well, what do you get for the voltage over C1 if you apply your first relevant equation ?
(after you determined -- qualitatively -- what happens with the current through the switch when it is closed and afterwards :smile:)
I think I got it, thank you.
With the answers given it's a piece of cake :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
